It is currently Sat Jul 26, 2025 2:22 am
PostPosted: Wed Dec 12, 2007 8:50 am
i'm about to buy some fretting tools pretty soon so i can actually finish something and i was wondering what are the absolutely necessary tools needed for a good fret job start to finish.
    I don't have much money to work with due to Christmas so i'm trying to spend the absolute least amount of money but with decent quality tools.
thanks guys,
andrew
PostPosted: Wed Dec 12, 2007 9:00 am
Either a fret press (or caul for the drill press) or hammer.
A very flat 10 or 12" file for flushing the ends and maybe leveling.
A tang nipper (if you are binding the FB)
A crowning file.
A triangular file (with corners ground smooth) for dressing the ends.
I use the StewMac aluminum caul for leveling, but a flat file will work.
Sandpaper for polishing.
That's all I remember. There are several approaches here, though, so you will get a lot more info than you want.
PostPosted: Wed Dec 12, 2007 9:38 am
First name: Wayne
Last Name: Clark
City: Driftwood
There was a discussion a couple months ago about these fret levelers. Pretty low cost solution.
PostPosted: Wed Dec 12, 2007 10:34 am
My short list:
-small hammer (I have an old cobblers hammer that is perfect...)
-end cutters
-triangular needle file with 2 faces ground flush
-fine flat file (8"-10") with the tang removed and stub ground smooth (or stew mac file with attached handle grip)
-Micro mesh set for finishing/polishing
If you properly dress the board and hammer, you won't need to level with a file, or re-crown for that matter. Tape the 1500 micromesh to a flat block if you must for leveling.
